Couple questions-turbo/fuel system+Quad
Have an 06 QC auto and have decided to go with the XZT and probably the boost fooler as well.
My question is what will the stock turbo handle for PSI and do I need to worry about draining the rail while towing 8500-10000 lbs in the hills?
I have gauges so I can monitor the boost and pyro levels but will the fooler and the xzt combo push the turbo too far under heavy loads?
Anything else I should take into consideration or look out for with this set-up? I do not have fuel pressure gauges but I can easily install them if recommended. Thanks for the info. -Jeremy
307Kenworth
Jun 27, 2011 08:23 AM
jmd025
Oct 4, 2008 04:42 PM
6 is better tha
Sep 12, 2007 10:16 PM
gman07
Apr 15, 2006 08:32 PM
