coolant change
Old Sep 1, 2012 | 06:47 PM
craigwill's Avatar
coolant change
Today I pulled the radiator out and cleaned all the oil/dirt off and pressured washed. changed the upper/lower hosed and T stat. My problem is that the temp goes up and back quickly. Do I have to purge the air out of the system? If so How? oh 2002 2500.
Craig
Old Sep 1, 2012 | 06:58 PM
Silver R/T's Avatar
Fill the cooling system with a 50/50 mixture of
water and antifreeze
Fill coolant reserve/overflow tank to the FULL
mark.
Start and operate engine until thermostat
opens. Upper radiator hose should be warm to touch.
If necessary, add 50/50 water and antifreeze
mixture to the coolant reserve/overflow tank to maintain
coolant level. This level should be between the
ADD and FULL marks. The level in the reserve/overflow
tank may drop below the ADD mark after three
or four warm-up and cool-down cycles.
Old Sep 1, 2012 | 07:33 PM
craigwill's Avatar
Thank you
Old Sep 1, 2012 | 10:59 PM
joem's Avatar
yeah, they purge the air well with silvers way, FYI my guage also goes up to 210 quickly, then dropps back fast when the t stat opens, then it creeps back up again then right at 210 dropps. Does this all the time.
Old Sep 1, 2012 | 11:12 PM
SIXSLUG's Avatar
My gauge hits 190 and then drops down, slowly building back to 190.
Since you cleaned up the radiator its doing its job a lot more efficiently now.
Nice work!
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mr. 45
Aug 8, 2011 12:25 PM
Mark Hodowanec
Aug 17, 2009 11:56 AM
popeyesides
Dec 6, 2004 03:43 PM
