Sponsored by: CARiD
Cold starting the cummins
Old Feb 6, 2003 | 10:11 AM
WA.Horseman's Avatar
8) I thought I would ask you experts. I know every one bags on the ford glowpug system. What does the cummins use? It has to have some sort of heating device. Thanks WRP 8)
Old Feb 6, 2003 | 10:22 AM
Iron Horse's Avatar
Re:Cold starting the cummins
The Cummins' use a grid heater that forces hot air into the cylinders.
Old Feb 6, 2003 | 10:25 AM
bulthisl's Avatar
Grid Heaters <br>They are in the intake system.<br>When you start your truck and you see your amp guage jump up and down. Or your head lights dim and come back thats what causes it. ;D ;D<br><br>Grid Heaters <br><br> : Eddie : 8)
Old Feb 6, 2003 | 02:30 PM
Scotty's Avatar
Top's Younger Twin
The Grid heaters will cycle and draw a lot of power unless you go over 25 mph....then they will shut off.<br>I saw what happens to the inatek horn when one of the heaters shorts out and stays on...makes a nasty mess of the intake horn...all brown and yellow and the wires were extra crispy.<br><br>Them heaters are real good at what they do and I usually put my running lights on during warmup so I can see when they stop dimming...then I know its nice and warm. The exhaust brake helps too...kinda like the Ford cold start flap, correct?
Old Feb 6, 2003 | 06:45 PM
richard's Avatar
The cummins also uses a fuel heater in addition to the air intake(grid) heater
Old Feb 6, 2003 | 09:47 PM
wheezer's Avatar
[quote author=CTD/359 link=board=8;threadid=10608;start=0#101524 date=1044563402]<br> The exhaust brake helps too...kinda like the Ford cold start flap, correct?<br>[/quote]<br><br>Yeah, the PSD I had worked pretty well. It would also idle a little higher (750 rpm vs. 500) when it was around or below zero.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
Hummin Cummins
Nov 18, 2002 12:41 AM
dodgeman01
Nov 14, 2002 06:08 AM
