clutch questions
Old Jan 7, 2003 | 06:25 AM
dodgeram's Avatar
clutch questions
okay I'm contemplating getting a clutch for my truck<br><br>question 1:<br><br> I'm going to run a edge comp or a tst pm3 and maybe a set of rv275's at the most so 300-350 hp<br><br>I'tll be used for daily empty truck driving with the power box off (for max fuel economy) 99% of the time, tow the ocasonal trailer, maybe 7000-10000 lbs max (again box off)<br><br>I just want the box for when I feel like fartin around, burning the tires, stop light draging ect.. ( the usual crap ;D )<br><br>so do I need a con OFE or will the con O do just fine<br><br>question 2<br> what are the con OFE and con O like for pedal pressure and engagement ....<br><br>I'm fat &amp; I got short legs so the seat is all the way back and I can't quite get the clutch pedal all the way to the floor ...stock clutch works fine for me, will either of those 2 be any different<br><br>question 3<br><br>how important is it that the flywheel be flat stone ground ..<br><br>I don't trust my local machine shop, they're the type that will nod yes when I tell and then just do it the usual tapered way anyways (I wouldn't know how to tell the difference)..<br><br>so would it really hurt anything if they did that...<br><br>all I can think of right now
Old Jan 7, 2003 | 09:14 AM
Hired Gun's Avatar
Re:clutch questions
dodgeram. <br>I had the South Bend Con Fe put in my truck a few thousand miles ago. It feels like stock with pedal pressure.<br>It is grabby in 2nd at take off. It is still breaking in. I love it because I pull trailers alot on the farm. It is very <br>streetable.<br><br>About the pm3. I get better mileage with it on 4 than with it off. You just have to learn how to keep the lead foot light.<br>I gained fuel mileage. I would leave it on. Now on setting 9, it will leave in a hurry, but man it feels good.<br><br>The flywheel is a 13&quot; replacement with the con fe. So I cant complain. I am a happy SB customer.
Old Jan 7, 2003 | 12:01 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:clutch questions
[quote author=dodgeram link=board=7;threadid=9313;start=0#89323 date=1041942313]<br>1) so do I need a con OFE or will the con O do just fine<br>2) what are the con OFE and con O like for pedal pressure and engagement ....<br>3) how important is it that the flywheel be flat stone ground ..<br>[/quote]<br><br>1) For what you say you're doing, Con O would be just fine. But are you really sure you're gonna stop at 350 HP, Derek? Got a nice little set of 3's sitting here looking for an owner <br>2) Pedal pressure will be as light as stock, maybe even a little lighter. Engagement will feel very much like stock. With either clutch that is.<br>3) Very important. Beat the machine shop guys with a stick until they promise to do as you ask &gt;<br><br>Rod
WACTD
Jul 25, 2006 11:41 AM
Fishbait
Jun 6, 2006 12:34 PM
mbmrang
Jan 21, 2006 12:49 PM
kwhite4
May 9, 2005 03:22 PM
