how to clean water in fuel sensor?
Old May 8, 2007 | 07:59 AM
estesbubba's Avatar
i plan on changing the fuel filter myself and the maintenance schedule says to change fuel filter and clean water in fuel sensor. i would guess the sensor is somewhere in the filter housing - is this correct? how do you clean the sensor?
Old May 8, 2007 | 09:48 AM
jkitterman's Avatar
You are suppose to wipe out the fuel filter housing with a lint free rag. It is tough to get your hand in there. The sensor is a little bit above the bottom.
Old May 8, 2007 | 09:32 PM
wreedCTD's Avatar
does anyone actually clean there sensor?
Old May 9, 2007 | 09:26 AM
GMScott's Avatar
Yeah, never actually cleaned anything when I replaced the fuel filter on my 04.5. Just opened the yellow lever and drained the canister 1/2 way. Never even changed the rubber O ring either. 330k miles with NO fuel related problems.
Now the new 6.7l is a bit different. Uses a complete spin-off unit that comes with a new sensor.
Old May 9, 2007 | 09:47 AM
jkitterman's Avatar
That may be one reason why the fuel filter setup was changed.
Brian.B
Dec 10, 2012 02:14 PM
DU.DP.
Mar 18, 2009 12:03 AM
SuperDave4x4
Sep 5, 2006 02:35 PM
tyssniffen
Feb 11, 2006 01:28 PM
tishmael
13
Dec 2, 2002 12:39 PM
