changing oil
Old Jan 1, 2006 | 07:52 AM
cartrl's Avatar
changing oil
Happy New Year everyone. Well I figured I'd head toward the garage yesterday and change the oil in the truck between football games. Easy enough right. Wrong! I could not budge the oil plug. I used some PB Blaster, which usually is a miracle in loosening frozen fasterners but as of last nite still couldn't budge. Has anyone had similiar experience and what did you have to do. Thanx.
Old Jan 1, 2006 | 08:04 AM
Geico266's Avatar
Sometimes I use a cheater bar because some money tightened it too tight. Did I mention I'm the only one that changes my oil?
Old Jan 1, 2006 | 09:26 AM
RowJ's Avatar
Have seen some put back in WAY to tight!
You'll just have to lean on it till it comes loose.
Good news is I don't think you can hurt anything down there.
And, if you have not heard it before... Fleetguard Filter only!!!!
https://www.dieseltruckresource.com/...ad.php?t=87505
RJ
Old Jan 1, 2006 | 12:57 PM
mkrenn's Avatar
I allways use a cheater bar. Don't know why they get so tight. Have to do the same on the T-case.
Old Jan 1, 2006 | 01:47 PM
fschiola's Avatar
I use a 1/2 " breaker bar with a 3/8" adapter to loosen it, and a 3/8" breaker bar to tighten it back up.
Old Jan 1, 2006 | 08:07 PM
cartrl's Avatar
success
Thanx for the responses. Went out this morning and used a torque wrench on the plug and when I heard a snap I was almost afraid to look but it broke loose. I had previously ordered a FP guage from Geno's and ordered fleetguard oil filters at the same time. Thanx again.
Old Jan 1, 2006 | 08:29 PM
tmoore's Avatar
I think I have just the opposite problem. I changed my oil early last week, had the truck in the garage today and it left a small puddle. So when I go under to check its leaking around the drain plug. Put the ratchet on it and it feels tight? I am always affraid of "tightening untill turns freely". Hope it took care of it, never down it before. Anyone else ever had that happen?
KSwanner
Jul 20, 2003 02:32 PM
My 03 HO
Jul 16, 2003 09:59 PM
Figlos
Jul 5, 2003 08:44 PM
sdgunslinger
15
Dec 28, 2002 07:31 PM
OH Sick
Dec 17, 2002 04:42 PM
