Cab mount repair
Cab mount repair
so ive got some major rust repair to do on my truck. mainly the cab mount brackets. they are pretty much rusted through and kind of sinking.
heres a vid i took.
http://www.youtube.com/watch?v=nUdVMLTN3_k
any advice? lifting the cab would make things easier, but i lifting the cab easy?
Looks as though you have cancer bad
Mine was to the point that I had to rebuild my cab mounts, rocker panels, cab corners and floor. I was closing my door by kicking it. Not a good thing !
I removed the box, hood, fenders, disconnected the clutch, fuel cable, break lines, booster hose, unplugged the wiring harness from the firewall, heater hoses, windshield washer hose, removed the transmission and transfer case covers and shifters ......... then jacked the cab up and rolled the chassis out from underneath it and rebuilt the cab.
You may be able to patch it while the cab sits on the truck but in my opinion it would be quite difficult to do.........I looked at it and opted to do a full restoration on mine. I completed all the work myself so it didn't cost very much to get the truck back to near perfect
I was going to scrap the truck but decided to rebuild it since it treated me so well.
Another 1st gen lives on !
And I no longer drive it in the winter......it saw enough salt in it's time.
Calcium kills !
Another 1st gen lives on !And I no longer drive it in the winter......it saw enough salt in it's time.
Calcium kills !
is there a simple way to just lift up that corner of the cab without removing all of that? what if i loosen the other 2 cab mounts on that side, could i then just jack the cab up a little bit without removing anything else?
its the passenger side.
little update.
jacked up the cab. removed bushings and bolt. mounting bracket that bolts to the frame is cracked. heres a pic.the view is from inside the cab looking down.
i figured id weld it since its pretty small.
no parts stores here sell the bushings and the dealers dont even have em.
looks like im using the old ones.
cool thanx, thats what i was thinking. just gotta find a washer with a big enough center for the bushing to fit.
what do you guys think of rust converter? i was planning to use that inside the bracket where i can get the grinder.
then welding reinforcement plates on the outside of the bracket.
J10495T
Sep 21, 2011 04:07 PM
chw
Dec 25, 2006 04:30 PM
