Cab mount bolts.
Old Jan 12, 2005 | 10:54 PM
rockwithjason's Avatar
Cab mount bolts.
I an having issues with sloppy steering and a rattle I can't seem to find. I read a post where a guy had found loose cab mount bolts on his rig so I broke out the factory manual and looked up the torque spec for cab mounts. The book calls for 60lb/ft . I crawled under my truck with the handy dandy torque wrench and I found that my cab mounts were way loose. I had installed step bars and apparently they were never tight enough or they worked loose. I snugged them up to 60lb/ft and took her for a drive. I really noticed a difference in how the truck drove. It wasn't nearly as sloppy feeling. If you have similar issues check your cab mount bolts.
Old Jan 13, 2005 | 04:29 PM
phox_mulder's Avatar
Good post.
I put nerf bars on mine shortly after I got it, but never knew the torque specs for them.
Something to do this weekend if the weather cooperates.
phox
anpconnors
Nov 25, 2014 02:09 PM
JKM
Oct 24, 2006 07:43 PM
Ironstone
May 3, 2006 10:01 PM
mxa
Mar 31, 2006 12:33 PM
