A/C compressor cycles?
Old 01-13-2007, 10:29 AM
skymiles's Avatar
My A/C compressor cycles on and off even when the air conditioner is not on. I know on most vehicle the A/C cycles with the defrost on to circulate the oil in the compressor but why when just the vent is on. Or is this just a problem with mine. And no the A/C does not blow cold air right now, but the compressor is cycling on and off. although I don't think as long as it should to produce cool air, it only runs for about 2 seconds on and 15 seconds off.
Old 01-13-2007, 12:51 PM
TIMMY22's Avatar
just recharge it.
If you can find someone with the gauges, it's 2 bottles at 12$ each.
mine has a slow leak, so I've resorted to just spending $25 each spring to recharge it.
Old 01-13-2007, 01:10 PM
67HotRod's Avatar
I pull the A/C fuse during winter...
Old 01-22-2007, 03:49 PM
dhughe2's Avatar
if you have the **** pointed at face and feet the compressor will constantly cycle. Switch it to either face or feet and it will stop.
Old 01-22-2007, 04:49 PM
skymiles's Avatar
OH I see said the wise man. Wonder why they did that?
Thanks for that tid bit.
Old 01-24-2007, 11:57 AM
SoTexRattler's Avatar
It's supposedly for dehumidified heating so the windows don't fog so readily..
(secretly, I believe that DC did it that way so the A/C compressor will be running as soon as you start the engine, thereby making the air so much colder so you will appreciate the meager heater they put in our trucks. )
I like 67HOTROD's solution!
K.
plow
01-14-2006 05:35 PM
deezul
10-07-2005 02:41 PM
niekrewb
04-06-2005 10:36 PM
screaminbanana
03-25-2005 10:05 PM
gkainz
03-10-2003 05:32 PM
Quick Reply: A/C compressor cycles?
