rpm drop when gridheater cycles.
Old Jan 10, 2006 | 07:29 AM
plow's Avatar
Is a rpm drop normal when the gridheaters cycle on cold mornings or should the engine just change load without a rpm drop?
Old Jan 10, 2006 | 07:43 AM
JD730's Avatar
How much is it dropping? What rpm is it idling at? Grids pull quite a bit of current so they are making your alternator earn its keep. Thus putting more load on the engine, with that a little drop in rpm at idle.
Old Jan 10, 2006 | 07:48 AM
plow's Avatar
it idles at 875 and will only drop alittle on and off until engine warms up good. the only reason I ask is because Ive been reading some posts that links bad pumps with a rpm drop, but they probably mean when the engine is completly warmed up.
Old Jan 10, 2006 | 07:56 AM
MnTom's Avatar
Totally normal. That is the alternator pulling a big load.
Old Jan 14, 2006 | 05:35 PM
Wolf_fighter's Avatar
bad pumps usually are more noticable when driving... slight hesitation lack of power in take off etc...
your small rpm drop is normal
deezul
Oct 7, 2005 02:41 PM
niekrewb
Apr 6, 2005 10:36 PM
screaminbanana
Mar 25, 2005 10:05 PM
fishin fever
Feb 22, 2004 08:32 PM
gkainz
Mar 10, 2003 05:32 PM
