Hazzards only work for a few cycles, then stop.
All the wiring for my lighting including trailer hookups is as it came from the dealers lot. When I turn on my hazzard flashers, they flash for 30 seconds or so then get stuck on just solid on. This will happen every time they are switched on, if you turn them off then on again, it happens again. I replaced the flashers and it made no difference. Turn signals work fine.
Anyone else have this problem?
Any ideas what is causing this???
I would have initially thought the flashers. That is what happened when my turn signals went out. What about the trailer relays under the hood? Im not sure if that has anything to do with that circuit. You could try to remove them. Infidel may have some more ideas if he comes around here in a while.... Good luck.
Ghost Ram
63
Feb 18, 2008 08:49 PM
