Busted Mirror Glass
Old 09-29-2006, 06:45 PM
4wlow's Avatar
Busted Mirror Glass
I managed to smack a mailbox today with my passenger side mirror. I have the electric heated fold out tow mirrors. I should be able to get away with just replacing the glass. The glass part has two separate mirrors. Anyone know where I could get replacement glass other than the dealer. Thanks
Old 09-29-2006, 08:32 PM
rustyshakelford's Avatar
you can usually find the whole assembly on ebay pretty cheap sometimes. hope it helps and good thing it didnt hurt anything else. those thing sure do stick out a ways
brett
Old 09-29-2006, 08:35 PM
ftltmp's Avatar
I broke mine on my 01 and I took it to a friend of mine who work for a glass and mirror place and he cut a piece of house glass and put it in.
Old 09-29-2006, 09:24 PM
J&L
J&L's Avatar
try burcoinc.com for your glass replacement.
JIM
Old 09-30-2006, 07:16 AM
Hairtrigger's Avatar
4wlow
I sent you a pm reguarding a mirrow
Old 10-02-2006, 09:31 AM
welndmn's Avatar
How did you disassemble the mirrior?
Old 10-02-2006, 11:14 AM
BigDave12768's Avatar
Go down to your local glass place that does windshields. They can order you an aftermarket mirror. Just cutting a mirror to fit will not work. You need a mirror with the heating filiments in it. So dealer or aftermarket. Your other option is to find a used on complete
Old 10-02-2006, 02:26 PM
ftltmp's Avatar
The heating element is stuck to the glass with adhesive , I peeled mine off and stuck it to the new glass. If you need to you can use a little spray adhesive to help it stick.
Old 10-10-2006, 09:50 AM
TonyB's Avatar
I whacked my passenger mirror over the weekend. Dealer has new glasss on order for $38. ETA Friday.
Not too bad...glad I don't have to replace the whole assy
Tony
Old 10-12-2006, 10:38 AM
mule3010's Avatar
Your dealer sold you just the glass? You lucky dog. I got jipped! They made me order the whole thing. $198.00 But I have an ST and no heat or power.
Joe
Old 10-12-2006, 10:49 AM
Jezzhuntin's Avatar
I busted mine on my chebby and my current CTD. I went to a glass shop, as someone has already said. the dealer told me cause they are heated I have to do the whole mirror. I called hog wash. Modern Glass in N ID replaced it for $20, yeah $20. the heat still works when I hit the button when fogged up. go to a glass shop. at the very least they can order it. Also, the mirror is only one piece, the convex part is part of the whole mirror, not two separate pieces.
Old 10-21-2006, 08:44 PM
TonyB's Avatar
Sorry to not update y'all...Baby came early & things are just settling down to a routine! Everyone is doing well!
So, a few things to be aware of when replacing the glass....
1) Not only are there 3 metal clips, there are 4 plastic tabs that the mirror mounts to.
2) Be VERY careful when removing the mirror. There is a circular peice of plastic that attaches to the back of the mirror you MUST reuse. Study it VERY carefully before attempting to remove. I'll take some pics & post later for more detail. The plastic slides off (the clips are tight!) the old mirror & slides/latches onto the new one. I broke one of the clips, but it was clean and I'm waiting for the glue to cure overnight.
3) The new mirrors have heating elements on both the flat mirror and the spot mirror. However, checking the impedance of the elements, the spot mirror is different enough that I probably won't connect it...the original had no connection.
HTH
Tony
Old 11-05-2006, 05:40 PM
BigHornCTD's Avatar
TonyB, I need to replace the glass in my passenger side mirror and would like to replace it myself. How do you remove the glass from the mirror assembly? Do you have any pictures?
Thanks,
-Jon
ncj01
04-26-2014 01:36 AM
jethroish
03-03-2014 10:09 PM
Patrick Campbell
10-24-2005 08:33 PM
Banzai Bob
03-04-2004 02:09 PM
damon_achey
07-30-2003 06:02 PM
Quick Reply: Busted Mirror Glass
