brake upgrade
Old May 11, 2011 | 09:02 PM
bakerroc's Avatar
brake upgrade
I'm looking at upgrading my rear brakes to the 1 ton version. A couple questions:
1. same cylinder and shoe part numbers for a D250 as for the W250?
2. Do you leave the ABS valving alone? Is it still functional?
Rocky
Old May 12, 2011 | 03:44 AM
PatJ's Avatar
Why not switch the rears over to disc's there's also a write up in the sticky
Old May 12, 2011 | 11:13 PM
bakerroc's Avatar
I thought about it. The 3" shoes and larger cylinders just looks so much easier for a shadetree mechanic like me.
Old May 13, 2011 | 07:58 AM
sooty's Avatar
way cheaper and easier, 3". auto parts store will have parts by application, new cylinders are probably 30. each, abs will be fine.
Old May 13, 2011 | 06:34 PM
dmill's Avatar
the P.O. of my truck apparently did the conversion, and when I did the brakes a couple weeks ago, I took the old shoes in to match them up and we had to look everything up under a 93 w350. The wheel cylinders are a little bigger than the 3/4 ton ones too. If I hadn't run my receipt through the wash I could help you more. I think when it was all said and done, I had a new master cylinder, new wheel cylinders, shoes, and all hardware including adjusters for right around 80 bucks (the fronts had recently been gone thru by the P.O.).
That said, the next time I need rear brakes, I am doing the disc conversion. Yea, it's a little pricey initially, but it beats the out of tearing the whole rear end apart just to get at the brakes, not to mention it should give you more stopping power.
Old May 14, 2011 | 10:58 AM
9453's Avatar
Check out these guys http://www.tsmmfg.com/ or this one http://www.egrbrakes.com/ all bolt on simply shadetree style a little spendy now but less work later my 2cents
NJTman
Jul 4, 2012 11:55 PM
LilBigd02
Feb 28, 2007 08:31 PM
cLAYH
Nov 12, 2004 04:51 PM
RTharaldson
15
Nov 4, 2004 07:20 PM
