Blower only works on High
Old 04-24-2006, 01:05 PM
HappyGA's Avatar
My blower for my air conditioner and heater only works when it is on the high setting.
I suspect that it is the blower resistor. It cost $51.00, and I plan on changing it out today to see if that is the problem. i will get back and let yall know.
key words for future searches: AC, heater, fan, control, panel, charge, power, troubleshoot, short, circuit
Old 04-24-2006, 10:07 PM
lglamb's Avatar
When you get it out, that little spring part is probably loose.
Some have fixed it (at least temporarily) by re-soldering it
back to it's post. I did this last week, and so far so good.
(of course didn't try this until after buying a new one, duh)
Old 04-25-2006, 01:04 PM
HappyGA's Avatar
thanks, I will try that before buying the new one. Might have saved me
$51 there buddy.
Old 04-25-2006, 06:18 PM
RODGERDODGER01's Avatar
same thing with my 1998, only works on high, where is this resistor ? Thanks
Old 04-26-2006, 06:47 PM
Timberman's Avatar
Pound on the dash board. Sometimes that helps with all sorts of problems!
Old 04-26-2006, 10:56 PM
lglamb's Avatar
"roof" of passenger footwell, next to blower motor, right next to firewall.
Couple small screws, wire connector. About 1" wide, 3" long.
Old 04-27-2006, 08:16 AM
HappyGA's Avatar
Yep, lay on your back in the passenger floor board. Look up under the dash. You will see a large round object, prolly 8" in diameter. That is the blower. Right beside that is a pice that is put in there right beside it with a quick connect wiring harness going to it. It is held in by two phillips head screws. Unscrew it, and pull it out. I have been trying to get to this all wekk, and will finally get to do it this afternoon. Like previously stated, might only need a little soldering doen to fix it.
Old 04-27-2006, 08:18 PM
Thanks all, will look at it this weekend....
Old 04-30-2006, 08:47 AM
Thanks guys, it was the plug in at the resistor, wasn't plugged in, now I have all 4 speeds but weird thing is, 2nd and 3rd position is reverse, 2 nd position is faster than 3rd position, hmmm....??? 1 is slow and 4 is the fastest.
chainzaw
10-14-2009 07:46 AM
hemertwv
09-16-2005 12:12 PM
SilverRam01
07-31-2005 06:36 PM
IntakeRacing
01-09-2005 06:27 PM
7mmrum
11-11-2004 07:08 AM
Quick Reply: Blower only works on High
