Blower Motor Resistor
Could someone tell me where the fan motor resistor block is located on a '93. Fan works on all speeds with a/c and vent, but it does nothing at all on heat or defrost. Thanks for the help.
I don't know if your resistor block is bad. It will only work on one speed or not work at all when it goes bad. It's mounted on top of the heater plenum with the fan wires going to it. With it working on a/c but not heat sund more like a wiring or switch problem.
It was the resistor block, pulled the plug off of it. It had 2 terminals that were some what rusted. Sanded them down, plugged it back in and is working on all speeds, heat and a/c. Thanks guys
Wow, learn something every day. I've never seen one act like that and just need a cleaning. Usually, when they get to this point, one of the resistor wires burns through.
Jim Lane
04-05-2020 06:03 AM
