block heater amperage
Old Nov 7, 2007 | 05:56 PM
MMarty's Avatar
Hey I just installed a block heater cord for my 05 dodge 2500 diesel. When I plugged it in my garage breaker (20 amp)tripped instantly in the shop. How many amps does it pull? Can the plug be installed wrong? Thanks
Old Nov 7, 2007 | 05:59 PM
jkitterman's Avatar
Is your outlet a GCFI? The heater is about 750 watts. 2400 watts would be 20 amps at 120 volts. Plug really can't be installed wrong but maybe it is shorting out somewhere or a bad heater?
Old Nov 7, 2007 | 06:02 PM
rustyshakelford's Avatar
i doubt theres anything wrong with the heater...check the cord again or you might have a weak breaker
brett
Old Nov 7, 2007 | 06:37 PM
RDM16CTD's Avatar
MMARTY
My 2005 block heater pulls about 6.5 Amps or 700 Watts from 120 VAC.
Hope this helps
Bob
Old Nov 7, 2007 | 09:44 PM
4thInf1969's Avatar
Mine pulls 6.5 to 7 amps. Can't run a toaster or coffee maker at the same time. It's probably a good idea to put it on a timer to start about 2 hours before you need your truck.
Old Nov 14, 2007 | 08:20 PM
spooled's Avatar
Is 1-2 hours about what most people set there timers for in the morning???
Old Nov 14, 2007 | 08:46 PM
4thInf1969's Avatar
Here in Kansas I set mine to kick on 2-hours before I expect to start the truck
Old Nov 15, 2007 | 08:07 AM
TedT's Avatar
I bet something else that draws a lot of current is on the circuit.
Ted
Old Nov 15, 2007 | 08:55 AM
John Faughn's Avatar
The more often a breaker pops , the lighter the load it takes to pop later , they can wear out / become weak .
90firstgen
Dec 14, 2007 12:49 AM
ChrisM55
Nov 4, 2006 01:09 AM
Patrick Campbell
Aug 8, 2006 11:39 PM
rjm022
Oct 12, 2005 07:13 AM
Kruchr
Jan 6, 2004 12:46 AM
