Best portable electric compressor?
Old Nov 4, 2007 | 11:27 AM
84mphcdt's Avatar
I want to buy a portable electric compressor soon to blow the water out of my drip system at the house between winter waterings. The guy at the irrigation store said the small ones for airing up tires wouldn't cut it. I saw what looked to me like some fairly substantial one at Sears for around $100...
Anybody have poop on best brands, sources, or anywhere where reliable reviews are published?
Old Nov 4, 2007 | 11:44 AM
Raspy's Avatar
From: Smith Valley, NV (sometimes Redwood City, CA)
Those little Craftsman red ones with the oil lubed compressor are very good. I have seen them on sale for as low as $89. So worth it even at $119.
My gauge broke for some reason (probably my fault) and when I went back to BUY a gauge the girl said "Oh we'll just warrantee it" and gave me a whole new compressor with all the attachments. Sheesh.
Senco also makes an oil-less one that comes in a kit with a very nice brad nailer. The compressor is very light and covered in a black plastic housing with about a 1.5 gallon tank. They are very good and will hold air for a long time. Very light too.
Either one is good for light jobs or running a nail gun, paint sprayer, etc. But not up to tire shop duty or plasma cutting or bead blasting. I use both of mine on the job 'cause they are so easy to carry around. I also use one to blow out the water from my trailer water lines for winter layup.
John
Old Nov 4, 2007 | 12:19 PM
TonyB's Avatar
84mphcdt, where do you live? I'm in AZ with a 220v wheeled portable compressor for sale.
Tony
Old Nov 4, 2007 | 02:05 PM
84mphcdt's Avatar
Thanks, Raspy!
TonyB, I'm in El Paso for a spell, but the compressor will be used in Northern NM.
Old Nov 4, 2007 | 02:11 PM
Equalizer 2's Avatar
If you get one that uses oil make sure to keep the thing reasonably level so as to not burn up the motor.
Old Nov 6, 2007 | 06:11 PM
EQUIPPRO's Avatar
Jenny air compresors are the best in portable. Good CFM and psi. Shoot me a PM if U R interested a little more than the Craftsman, but will last 2X as long. Quality motors and frame.
Old Nov 6, 2007 | 08:18 PM
84mphcdt's Avatar
Thanks!--here's links so far:
http://www.sears.com/shc/s/BrowseSub...&sbv=Craftsman
http://www.senco.com/con_rem/prod_finder.aspx
http://www.jennyproductsinc.com/port...handcarry.html
Old Nov 6, 2007 | 08:31 PM
Raspy's Avatar
The one I have and was recommending is the Sears 3 gallon, 1 HP model for $99. I dont see the Senco model I have but the Sears is a better unit.
John
t-boe
Mar 16, 2009 06:26 AM
May 25, 2003 04:51 AM
Homestead
Apr 24, 2003 11:27 PM
Bobp
Mar 14, 2003 05:52 AM
