Banks Exhaust install ?
Old 01-25-2008, 09:33 AM
rogers259's Avatar
I installed a Banks Exhaust last night on my truck and of course after installing began to question if I put it on backwards??? I know this sounds stupid but when I went to put the muffler on it was flanged on both sides and therefore could be put on either or. I installed it like the diagram in the manual...but could I have installed it backwards?
Sound wise...at idle in cab quieter than stock, cruiseing at 65 its got a nice tone to it. However if I accelerate hard its really barks loud and around 2k rpm if I accelerate to change lanes it starts to get pretty loud in the cab. I dont recall my friends sounding like this when I test drove his 6 months or so ago. So thats why I'm wondering if I could have installed that muffler backwards.
anyway thanks for the help.
Old 01-25-2008, 09:57 AM
Spooler's Avatar
I often have wondered the same thing. That is exactly how mine sounds. I have no idea.
Old 01-25-2008, 10:16 AM
Lrdchaos's Avatar
same here....I really like it though.
Old 01-25-2008, 10:29 AM
DADDY'S DIESEL's Avatar
I have heard it can be installed backwards which will make it sound different.
Only way to truly find out is to reinstall it the other way.
Old 01-25-2008, 10:34 AM
rogers259's Avatar
Its a straight through muffler so I really don't see how it could possibly be installed backwards. I just dont recall my friends sounding that loud in the cab when getting on it. Maybe it just needs to break in some? I guess I'll find out tonight...I have to drive to WI (725 miles) so will see how it does.
I will say the low end response is much better, EGT's seem to be down about 50* while cruising 65-70. But no black smoke
Old 01-25-2008, 10:45 AM
rogers259's Avatar
Ummmm....Considering it took me 6 1/2 hours to get that stock system off and I can't begin to tell you how bad my back feels this morning. No way am I attempting that again. Besides whats the secret to getting those hangers out without cutting the tips off and backing them out? I made the mistake of installing the pipe over the rear axle and hanging it in the hanger then trying to install the muffler....imagin this me (6'3" 210) under the truck right leg over the axle braced and pushing against the hanger left leg locked around the tire and trying to coax that darn pipe into the back of that muffler.... Otherwise install was only 20 minutes and if I had read the directions fit perfect
I guess if I installed it backwards its going to the muffler shop to get redone cause I'm not getting back under there in 4* weather to fix it
Old 01-25-2008, 10:46 AM
I heard a lot of things that were not true this just might be a nother one.
O well.
Old 01-25-2008, 02:33 PM
Spooler's Avatar
Are you talking about the rubber hangers???? If you are you need lots of PB Blaster, spray silicone, or WD40 and a big prybar. Makes short work of it.
Old 01-25-2008, 03:27 PM
cdennyb's Avatar
Location: In Oroville, Ca., same house for past 46 yrs!
I have to ask...
Did you have a CAT on there as well? You can look into the muffler (at least mine) and see a stamped arrow on some of the primary baffle plates.
Oh well, never mind... you'd have to lay under the ol girl in 4* weather and suffer thru another back wrenching exercise to even see it.
Forget I said anything....
Old 01-25-2008, 03:41 PM
Sinbadd's Avatar
I get the hangers off by spraying them with wd40 and using a large pair of channel lock pliers on the rubber part and the metal pieces that go through them. Give it a good squeeze and they come right out. The banks muffler is supposed to have an expansion chamber on the inlet side and is the same as pipe ID on the outlet side. Mine also had the word inlet lightly stamped on one side.
Old 01-25-2008, 11:35 PM
Spooler's Avatar
I checked mine tonight and it is stamped INLET on the canister right behind the welds on the bottom of the muffler. I installed it 2 years ago so I did it right.
Old 01-26-2008, 12:20 AM
Performance's Avatar
If it's a Banks Monster Exhaust, you should be able to read the writing (Banks MONSTER Exhaust) on the muffler clearly from the passenger side of the truck. It would be installed backwards if you can only read the writing from the driver side.
Old 01-26-2008, 12:25 AM
Luvnacumns's Avatar
6-1/2 hours holy moly man... I can do a whole 5" exhaust in an hour by myself... The hangers are a pia..... but once you figure out how they work it's easy I don't even use lubes....
Old 01-27-2008, 08:26 PM
rogers259's Avatar
LOL...yeah I put it on backwards...guess if I had bothered to look at the muffler I would have seen the stamp that said "input"
yeah I guess it took quite a bit longer than it really should have
Old 01-27-2008, 10:03 PM
O well.
I guess not.
Big Dblue
10-07-2008 12:19 PM
Common
02-27-2008 09:44 PM
civicrr
06-09-2007 03:28 PM
PourinDiesel
21
04-30-2007 09:55 PM
bradmulvey
01-27-2006 12:18 AM
Quick Reply: Banks Exhaust install ?
