bad gas mileage
Old 04-07-2007, 11:03 AM
906577's Avatar
bad gas mileage
i have a 98 ram 2500 with the 24 v cummins and im getting really bad gas mileage with it why would this be
Old 04-07-2007, 12:16 PM
ohiostate24's Avatar
I was too. I cleaned up my air fliter and now my mpg are back to normal. It could be the winter blend of fuel too.
Old 04-07-2007, 12:34 PM
24vCTD's Avatar
Don't forget to check tire pressure--if your tires are low they can create a lot of rolling resistance, bumping the mpg way down. How are you getting bad gas mileage with a diesel anyway?
Old 04-07-2007, 12:35 PM
Philabuster's Avatar
You're burning gasoline in your Cummins?
Old 04-07-2007, 01:00 PM
CODODGE2500MAN's Avatar
WHat about a fuel filter?
WOuld this be cause for it too?
How about your trans if you have an auto? is your tq converter slipping? That might cause some loss in mpg!
Old 04-07-2007, 01:55 PM
fbx22's Avatar
Mine is TERRIBLE as well. So I will let you know as soon as I figure out why. Tire pressures are 65 front and 70 rear. Power service is used. Air filter is clean, and its still getting about 10 or 11 mpg city. Could be winter fuel mixture? but thats what the additive is supposed to fix right? I just switched fuel brands. My next trouble shoot attempts will be fuel filter replacement and put in 5w40 synthetic oil. The idiots at the chrysler place put 5w30 synthetic in there but I wouldnt think that would bring down mpg since its thinner. Then if thats not helping I will be have to have the trans serviced and adjusted. Not the fuel pump is it? I would think since Im burning lots of fuel that its pumping plenty of fuel?
Old 04-07-2007, 02:43 PM
kevellis32's Avatar
You are probably gettin bad gas mileage b/c gas isn't supposed to be run in a diesel
Old 04-10-2007, 12:46 PM
Olratlr's Avatar
Repeat after me Fuel Mileage, Fuel Mileage, Fuel Mileage.
Old 04-10-2007, 05:16 PM
Tate's Avatar
I always take a hit in mileage when it goes to winter fuel. It gets thinned out, and has less energy per volume. Additives help it keep from gelling, but won't get your lost mileage back.
Old 04-10-2007, 06:26 PM
Administrator / Scooter Bum
Shovelhead's Avatar
Speed in excess of 60 mph will KILL your mileage also.
It's a pickup truck with all the aerodynamic qualities of the average brick, not a Lamborghini.
Running down the road at 80 will reduce your MPG by quite a few MPG.
Old 04-10-2007, 07:00 PM
99globalwarmer's Avatar
yes its fuel,when you put fuel in it you go to a fueling station. check fuel filter, check air filter, fill out your sig.so we know what you have going on.i get better than that.sounds like you need to do a tuneup.
Old 04-11-2007, 08:24 PM
Toolbox's Avatar
I've heard cleaning your intake air temp sensor can help, though it didn't help me. I'm getting about 15 though, which most people have told me is normal for a 4x4 dump truck.
Old 04-11-2007, 08:46 PM
fbx22's Avatar
well mine is up to 13 in the city, now that Im not having to idle in the mornings. I plan on changing the fuel filter here in a few weeks and hopefully that will add a few more. I get great MPG in OD but those other gears are gobbling up the fuel Stop lights every few blocks means I hardly ever get passed 3rd gear. At least when I go to work at 530am the roads are pretty empty so Im able to run at reasonable speeds without having to stop at the lights since they stay green unless a car is coming from the other direction
Old 04-12-2007, 11:17 AM
winger's Avatar
When was the last time you had the fuel filter checked/changed?
I'm getting 20-22 mpg in mixed driving and only a very slight drop during the winter. And thats with a Gale Banks Performance kit.
smokin92
01-16-2008 11:43 PM
THURENfab.
08-08-2007 07:02 AM
Scovo1
30
05-11-2007 01:08 PM
04ctd
15
04-30-2006 08:45 AM
hipsi
06-01-2005 03:50 PM
Quick Reply: bad gas mileage
