Auxillary input to stereo
Old Jan 12, 2005 | 03:36 AM
jrs_dodge_diesel's Avatar
Question Auxillary input to stereo
I have the Infinity premium radio in my truck. To be more specific it has a single disck player, the low-mid-high- equalizer sliders, and a joystick for the speaker fade and balance. Does anyone know if this radio is capable of an auxillary audio input? I have an MP3 player that I would like to tie into the system since the CD player suck at playin burnt CD's.
Old Jan 12, 2005 | 05:38 AM
2500CTD's Avatar
Well not any really help, just glad to know I'm not the only one with that problem of playing burnt CD's. Just for that reason, I'm putting in an older head unit I have. Also while I was back there I did not notice any aux inputs either. Not unlesss you can do a FM turner style input.
Old Jan 12, 2005 | 07:54 AM
Bart Timothy's Avatar
My '01 will play them as long as the CDs are CD-R music.
Old Jan 12, 2005 | 08:17 AM
milehighfly's Avatar
Mine will play -R with no problems.
Old Jan 12, 2005 | 09:32 AM
infidel's Avatar
From a discussion on another board I learned it depends on the brand of disc that you burn to whether they will play well in the stock Infinity.
I went though the same thing with the aux inputs last summer as I wanted to use my iPod though the Infinity.
Ended up buying a Sony xPlod 50 watts per channel mP3 player with auxiliaries for $125. Works and looks great, installed in 20 minutes. Now I burn my music onto mP3s and use no cds, having one disc sure beats twelve with the same amount of music.
Old Jan 12, 2005 | 10:07 AM
firestorm's Avatar
dido
Old Jan 12, 2005 | 12:55 PM
Citizen's Avatar
Mine plays CD-Rs as well.
There are two solutions you can use if you don't want to replace the head unit. You can get a converter that will change the back factory pre-outs to a 3.5mm(headphone) jack. But I think the piece is expensive and you have to bring it out the front somehow.
The other way you lose a little sound quality, you can use a tape deck to 3.5mm jack converter. This is what I have been doing while I decide if I want to do anything else long term. It lets me use my mp3 player and my laptop.
If you try to replace the head unit from the Infinity's the speakers won't work right with an aftermarket unit. Each of the speakers is self powered I think. I tried it and it was a no go for me. You end up have to rip out the entire system.
There are several threads on all of this with more information if you search the archives.
Old Jan 12, 2005 | 01:44 PM
infidel's Avatar
My aftermarket unit had a wire just for this, if you get one that doesn't use the wire on the new unit for the power antenna to power the speakers.
Old Jan 12, 2005 | 01:56 PM
TRAVIST's Avatar
It is possible. I just did the same thing for my 04.5 rbk radio. Check out the following link. They have all kinds of interfaces to go with just about any stock radio to give you an auxillary input. www.pie.net
Old Jan 12, 2005 | 02:23 PM
Nvisable's Avatar
Check out: http://www.crutchfield.com/S-bsNFRbf...900&I=581DFCHR
It uses the factory CD-Changer input on the back of the head to allow two AUX inputs.
I'll be using this method when I start upgrading the stereo. PIE is the other brand.
Old Jan 12, 2005 | 06:49 PM
infidel's Avatar
I considered using the CD-Changer adaptor method but with the price of it almost half way to the price of a new head unit that is better than the Infinity figured why mess with it.
Also tried a FM modulator and a cassette adaptor, both sounded crummy.
Old Jan 12, 2005 | 11:08 PM
Citizen's Avatar
I've tried the FM modulators too and was very unimpressed.
Old Jan 13, 2005 | 03:59 AM
I have an FM modulator and it sucks. That is why I am interested in the auxillary input.
Now something is confusing. A CD changer input, how does one switch to that source if you want to listen to that input?
Old Jan 13, 2005 | 07:58 AM
Nvisable's Avatar
Based on what I read you would use the "Mode" button on the head unit to switch between inputs.
Joe Diesel
Nov 12, 2007 08:59 AM
Dane Bramage
Mar 1, 2007 01:09 PM
kayjh
27
Nov 15, 2005 05:04 PM
infidel
Jun 11, 2004 08:35 PM
DF5152
24
Jan 4, 2004 05:57 PM
