Anti drain back valve for compressor??
Old 09-06-2007, 08:13 PM
Asher's Avatar
I need to install a anti drain back valve for my air horns, the compressor is allowing the tank to drain out over night and I want to place a one way valve to keep this from happening.
Where can I find a valve for this application??? (120 PSI range)
Old 09-06-2007, 08:16 PM
rustyshakelford's Avatar
ball valve!
brett
Old 09-06-2007, 10:14 PM
ptgarcia's Avatar
Originally Posted by rustyshakelford
ball valve!
brett
Got a link to one that would work? I could use one myself.
Old 09-06-2007, 10:26 PM
TonyB's Avatar
Search http://www.mcmaster.com/ for "Spring Check valve" You'll go right to the page & see several sizes and types. Watch the temp range, if you are in a cold winter climate. I think most of what I saw on the middle of the first page should work for you.
HTH
Tony
Old 09-06-2007, 11:03 PM
cbrahs's Avatar
home depot! cheap and local.
Old 09-06-2007, 11:05 PM
ptgarcia's Avatar
Is Viton better than Buna-N?
Old 09-06-2007, 11:12 PM
ptgarcia's Avatar
So, if I get one of these:
and two of these:
I should be good to go, right?
When I broke some of my exhaust brake fittings I tried the stuff from Home Depot and they don't fit the 1/4" Viair air line very well. I couldn't get them to seal. Finally had to get parts from Pacbrake. Must have wasted $20 of fittings. I won't be using them again!
Old 09-07-2007, 12:05 AM
Rough-n-Ready's Avatar
All you need is one of these.
They are made by SMC, other manufacturers make similiar products and should be available from an industrial pneumatic supply house. I use these all the time in industrial applications.
This is a check valve built into a straight tubing coupler. All you need to do is cut the tubing and insert the ends of the tubing into each end of the valve. Simple.....
Old 09-07-2007, 12:14 AM
It depends on the application. Viton is a little more resistant to heat and chemicals than Buna-N, but it has a slightly higher durometer, means it is a little harder.
In regular sealing applications, Buna-n seals better, but if you need better chemical or heat resistance, better to go with Viton.
Old 09-07-2007, 12:32 AM
Try this for a link to a check valve that should work.
http://www1.mscdirect.com/CGI/NNSRIT...53784&PMT4NO=0
JayBird Enero
01-20-2016 11:34 PM
klx650a2
01-10-2008 12:08 AM
Lyall
09-07-2006 06:38 AM
TurboTed
02-11-2004 05:47 PM
BADodge2003
08-24-2003 07:22 PM
Quick Reply: Anti drain back valve for compressor??
