Anti drain back valve for compressor??
I need to install a anti drain back valve for my air horns, the compressor is allowing the tank to drain out over night and I want to place a one way valve to keep this from happening.
Where can I find a valve for this application??? (120 PSI range) |
ball valve!
brett |
Originally Posted by rustyshakelford
(Post 1683056)
ball valve!
brett Got a link to one that would work? I could use one myself. |
Search http://www.mcmaster.com/ for "Spring Check valve" You'll go right to the page & see several sizes and types. Watch the temp range, if you are in a cold winter climate. I think most of what I saw on the middle of the first page should work for you.
HTH Tony |
home depot! cheap and local.
Is Viton better than Buna-N?
So, if I get one of these:
http://www.mcmaster.com/catalog/113/...e/7775kp2l.gif and two of these: http://www.viaircorp.com/images/92838.jpg I should be good to go, right?
Originally Posted by cbrahs
(Post 1683360)
When I broke some of my exhaust brake fittings I tried the stuff from Home Depot and they don't fit the 1/4" Viair air line very well. I couldn't get them to seal. Finally had to get parts from Pacbrake. Must have wasted $20 of fittings. I won't be using them again! |
1 Attachment(s)
All you need is one of these.
They are made by SMC, other manufacturers make similiar products and should be available from an industrial pneumatic supply house. I use these all the time in industrial applications. This is a check valve built into a straight tubing coupler. All you need to do is cut the tubing and insert the ends of the tubing into each end of the valve. Simple..... Attachment 15163 |
Originally Posted by ptgarcia
(Post 1683362)
In regular sealing applications, Buna-n seals better, but if you need better chemical or heat resistance, better to go with Viton. |
Try this for a link to a check valve that should work.
http://www1.mscdirect.com/CGI/NNSRIT...53784&PMT4NO=0 |
