Alarm goes off randomly
Old 05-25-2009, 12:22 AM
Tedonlin150's Avatar
So the alarm on the truck started going off by itself today. The key fob will not turn it off either. I pulled the horn fuse to make it stop and plugged it back in a few hours later. That worked for a while but then it started again. Anyone got any ideas on what might be happening? Thanks
Old 05-25-2009, 12:44 AM
annabelle's Avatar
Mine does the same thing.
Old 05-25-2009, 07:50 AM
Did you do anything to fix it or do you just live with it?
Old 05-25-2009, 08:53 AM
annabelle's Avatar
Have just lived with it.......didn't have any luck fixing it.........pull the fuse to the horn when it gets too bad
Old 05-25-2009, 09:02 AM
Apache1's Avatar
Mine was the dealer transport fuse unseated in the fuse block. Fuse is removed when they transport the truck and installed by the dealer as part of dealer prep.
Don't recollect which number it was. Took awhile till I understood what was causing it. Dealer said it was common and can occur long after installed.
Mike L
10-14-2013 12:02 PM
crxallwayswins
02-17-2010 12:59 AM
2006Mega
01-15-2010 08:54 AM
Bobcat698
05-03-2007 08:08 AM
converteddzlr
07-29-2005 01:35 PM
Quick Reply: Alarm goes off randomly
