airflow
Old 01-03-2008, 09:28 PM
ziggy's Avatar
airflow
okay, this may be an off the wall question, but is there a way to get the air going in quicker to a stock air intake box? I'm putting in an amsoil cleaner and was just day dreaming about it. Kinda like a ram air intake, but just opening for easier intake when the turbo kicks in.
again, it may be off the wall, but figured i'd ask anyway
Old 01-03-2008, 09:36 PM
DTR's 'Go to Guy'
vzdude's Avatar
Do a search for air box modifications ( might be airbox too ) . There are tons of people that have swiss cheesed them, put 4" holes in the bottom of them. Anything you can dream up!
Old 01-03-2008, 10:07 PM
cbrahs's Avatar
i cut a gallon paint can sized hole in the bottom of mine.
Old 01-04-2008, 12:39 AM
mostly stock's Avatar
i drilled a 4" hole in the bottom of my box, screwed a flange in the bottom, attatched some heavy duty dryer ducting with a grate on the other end (all from hardware store,maybe $12)
took out the passenger fog light mounted the grate in the hole.
homemade ram air...
Old 01-04-2008, 07:46 AM
Tree DR's Avatar
Quicker?
Why not put a fan inside the intake box and gain 50hp at 1700rpm like I did on a dyno.
Now the fan won't help or hinder at full throtle. Just gets the air to the turbo so it doesn't have to suck air in at low boost.
Old 01-06-2008, 01:14 PM
ziggy's Avatar
how did you mount it? and how powerful of a fan did you use?
Old 01-17-2008, 01:26 PM
Tree DR's Avatar
More air
Mounted it on top of the air filter, inside the box. It's a 1,400cfm fan. Found it at http://www.partzfinder.com/electric_..._fans_s/28.htm If you want anymore info PM me.
There are several threads on here about it. Do search for intake fan.
trik396
05-14-2005 10:11 AM
GO 4LO
08-24-2004 02:55 PM
Pat-3500
22
12-05-2003 09:48 PM
Timinva
17
08-21-2003 08:45 AM
patriot pearl blue
12-15-2002 12:10 AM
Quick Reply: airflow
