airflow
airflow
okay, this may be an off the wall question, but is there a way to get the air going in quicker to a stock air intake box? I'm putting in an amsoil cleaner and was just day dreaming about it. Kinda like a ram air intake, but just opening for easier intake when the turbo kicks in.
again, it may be off the wall, but figured i'd ask anyway
i drilled a 4" hole in the bottom of my box, screwed a flange in the bottom, attatched some heavy duty dryer ducting with a grate on the other end (all from hardware store,maybe $12)
took out the passenger fog light mounted the grate in the hole.
homemade ram air...
homemade ram air...
Quicker?
Now the fan won't help or hinder at full throtle. Just gets the air to the turbo so it doesn't have to suck air in at low boost.
how did you mount it? and how powerful of a fan did you use?
More air
Mounted it on top of the air filter, inside the box. It's a 1,400cfm fan. Found it at http://www.partzfinder.com/electric_..._fans_s/28.htm If you want anymore info PM me.
There are several threads on here about it. Do search for intake fan.
trik396
May 14, 2005 10:11 AM
patriot pearl blue
Dec 15, 2002 12:10 AM
