airflow questions
Old 05-09-2007, 11:23 AM
wreedCTD's Avatar
airflow questions
Can someone explain how the air flows thru the cummins? from intake to exhaust. i dont understand how it works with the turbo?
Old 05-09-2007, 12:48 PM
Joe T's Avatar
Into the turbo, through the intercooler (located up behind the grill), into the motor, and out the exhaust.
Old 05-09-2007, 12:49 PM
wreedCTD's Avatar
the turbo has 3 inlet/outlet what do those do? obviously 1 is intake, and 1 is exhaust.
Old 05-09-2007, 12:51 PM
Joe T's Avatar
one is intake side in, intake side out, and then exhaust in and exhaust out.
the exhaust coming out spins the turbo, it is broken down into two sides.
Old 05-09-2007, 12:52 PM
wreedCTD's Avatar
so where the turbo mounts to the motor is is split into 2 sections? intake and exhaust.
anyone have a pics?
Old 05-09-2007, 12:53 PM
wreedCTD's Avatar
wait i think my last post i am confused, correct me please.
Old 05-09-2007, 03:02 PM
Lil Dog's Avatar
The exhaust side is the waterwheel to the mill. Exhaust out through the turbine side to spin the shaft and then out through the tail pipe. Center section of turbo with oil in and bearings etc. Compressor side of turbocharger has fresh air intake to center of the compressor wheel, air is spun out to the outside of the compressor housing and high velocity (air slows down to create pressure) and then out to the intercooler for cooling from compression. From intercooler to intake manifold of engine.
Depending on the fuel demand of the engine, the turbocharger will spin at different speeds (up to 100,000 rpm) to provide boost pressure for the intake manifold. No load on the engine, the turbo provides little or no boost unlike a belt or gear drive supercharger.
Old 05-09-2007, 05:25 PM
winkle's Avatar
Check out this link
http://auto.howstuffworks.com/turbo1.htm
trik396
05-14-2005 10:11 AM
GO 4LO
08-24-2004 02:55 PM
Pat-3500
22
12-05-2003 09:48 PM
Timinva
17
08-21-2003 08:45 AM
patriot pearl blue
12-15-2002 12:10 AM
Quick Reply: airflow questions
