AirDog?
Old 11-10-2009, 11:28 PM
choppers555's Avatar
AirDog?
Does the Air dog replace your stock fuel filter? Or does it just add 2 more filters before it runs into your stock fuel filter? Are they a good investment?
Old 11-11-2009, 01:06 PM
Diesel87's Avatar
You can run it to your fuel filter, but that would defeat the purpose. My fuel line goes from the AD to the CP3. AirDog has a 2 micron fuel filter. People say their water seperator isn't as good as stock, but my dealer said the water filters with the metal screw on the bottom are much better than the older plastic ones. The metal screw just means it is the newer version filter.
Old 11-11-2009, 07:53 PM
Spooler's Avatar
I ran mine to through my stock filter. I use it as my last chance filter before the CP3 as you should have one just in case a problem arises.
Old 11-11-2009, 10:14 PM
psd1's Avatar
What does the manufacturer say about keeping the stock cannister?
Old 11-12-2009, 01:32 AM
Spooler's Avatar
Said it was fine.
Old 11-12-2009, 09:36 AM
psd1's Avatar
makes sense to me to keep it then right, or do the big powa guys need more fuel than it can push thru the stock can?
Old 11-12-2009, 08:11 PM
1985cucv's Avatar
the only restriction is the line from the stock canister to the cp3 it is small vulcan makes a big line kit for this nice set up!
Old 11-12-2009, 08:28 PM
Mexstan's Avatar
I bought the bypass and removed the LP and stock filter.
It's a pain to reach the banjo fittings on the bypass. Need a longer arm and one more elbow.
01blackspeeper
03-23-2012 04:52 PM
Tractor Truck
01-20-2011 01:56 AM
kdbvulcan
20
12-06-2008 04:34 PM
gatf4
01-28-2005 10:19 PM
gatf4
12-27-2004 12:22 PM
Quick Reply: AirDog?
