AFC/Fuel Pin Cleanup Question
I checked my fuel pin the other day to see if it was sticking, and noticed I had alot of what appeared to be dirt down the AFC shaft and close to the breather hole where that rubber piece covers on the outside.
My question is this:
Is it safe to spray that down with some break cleaner or WD40 and then blow all that stuff out with air or is there another way? I guess WD would work better as I stand to cut the grease off the pin if I used break cleaner. Just wanting to make sure there are other reasons I am not seeing for doing this a different way.
Thanks!
Thanks!
KATOOM
Dec 17, 2011 09:20 PM
Ghost Ram
62
Feb 19, 2008 02:00 PM
pacmule
Sep 5, 2007 08:47 PM
