ABS light...how to turn off?
Old Nov 5, 2008 | 05:14 PM
redneck1's Avatar
My dust guards for the ABS have rotted away and the brass got very dirty. As a result my ABS light came on and it has been 3 months and it will not shut off. Does anyone have any idea how I can get light to go out? Other than disconnecting it.
Old Nov 6, 2008 | 01:03 AM
Dinner's Avatar
I would think its either let it burn out, or remove the dash and take out the bulb.
Old Nov 6, 2008 | 03:07 AM
drolex's Avatar
Fix the ABS.
Do you have anything pluged into your OBDII port?
I was using power from the OBD port for my boost gauge before, and that tripped the Brake and ABS lights.
Old Nov 6, 2008 | 04:34 PM
redneck1's Avatar
Originally Posted by drolex
Fix the ABS.
I did clean the brass gears and ABS sensors thoroughly . There is nothing plugged into the OBDII port. I guess I might have to take it in to have the idiot lights turned off.
Old Nov 6, 2008 | 06:08 PM
infidel's Avatar
Have you tried disconnecting the batteries?
Old Nov 6, 2008 | 07:51 PM
allrdcowboy's Avatar
A piece of electrical tape should work.
Old Nov 6, 2008 | 09:31 PM
chariotdriver's Avatar
Screwdriver and....
a hammer. Break the bulb glass and it'll go out very quickly. So will the ABS part of the braking system
Old Nov 7, 2008 | 04:16 PM
redneck1's Avatar
Who needs ABS anyways. Look at Fred Flinstone, ever see him get in an accident?
Old Nov 9, 2008 | 12:56 PM
jbone's Avatar
Sometimes the ABS light will come on if one of the wires going the the sensor on the ring gear breaks. Check the wire going to the top of the differential housing-that's what caused my ABS light to come on. Good luck.
Old Nov 11, 2008 | 05:49 PM
imbodie's Avatar
Which Diff? my ABS light is blinking once about ever 2 minutes.....I just noticed it today, have seen "something blinking" for the last month or so but it blinks SO quick I never could catch WHICH light was blinking.... and obviously no codes were throwing.
-Tim
Old Nov 11, 2008 | 06:28 PM
98whitelightnin's Avatar
The rear diff, there is sensor that goes inside the top that controls the speedo and the ABS.
Old Nov 12, 2008 | 11:13 AM
omlambu's Avatar
I do not know if these trucks have adjustable spacing between the sensor and the reluctor ring but if it is adjustable try checking that.
Old Nov 12, 2008 | 06:45 PM
redneck1's Avatar
It's not adjustable and I did check the sensor in the Diff. All is ok. I guess 'll just go in and get the ABS reset.
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
mr T
Feb 24, 2007 06:42 AM
RottnRam
Sep 22, 2005 04:38 PM
j28s
Dec 5, 2002 07:33 PM
