clutch wont disengaged
I have a sb con fe with upgraded hyd. the clutch wont disengaged I have tried to adjust the rod all the way out , when I noticed that the nuetral safety switch part of the clutch master cylinder has seperated from the main bodt, I cannot for the life of me get the plug in free any one have this problem, I'm sitting in my yard stuck till I get a clutch fixed
Not sure understand your verbage, but gather clutch will not release.
Standard recomendation is buy the kit from friendly Dodge dealer. It comes preassembled. You can also purchase from Southbend dealer a aftermarket complete kit. It may have a larger bore for less pedal pressure on higher pressure clutchs and may be a few dollars higher then a friendly dealer. Try moparwholesale.com for reference. Do not recomend the individual pieces for repairs. Difficult to bleed and get to fit. JMHO
Sounds like you already have the SBC hydros, when you start the truck in netural can you hear the clutch releasing and engaging. Clutch could be glazed and just need to be forcefully seperated by pushing on the clutch pedal. A little more info is needed.
rustydeeretech
Jun 16, 2010 09:41 AM
Stroked-Z
Oct 4, 2008 11:28 AM
Backwoods Bumpers
Nov 20, 2007 08:01 AM
Dufrain
Oct 17, 2004 07:46 AM
