99 block in 1st Gen??
Old Aug 19, 2006 | 01:06 PM
mopar2ya's Avatar
Are the blocks the same for the 99 as the 93? Do all the accessories bolt in the same?
Old Aug 19, 2006 | 03:28 PM
linetrash75's Avatar
From what I understand the 24valve blocks are a little heavier in the webbing for the mains, but thats the only difference well I guess the head bolt holes and suck are different too, just speculation though.
Jed
Old Aug 19, 2006 | 10:08 PM
JD730's Avatar
As far as I know there's no reason you can't put 12 valve pistons in, change the front cover and cam, put on a 12 valve head and all the associated stuff and call it a 12 valve. I'm running a modified 12 valve marine gasket in my 24 valve.
Old Aug 20, 2006 | 03:32 AM
frostie's Avatar
If you start with a bare block, you should be OK. a 99 is a 24 valve engine and will have different pistons.
Make sure the 99 block does not have a "53" casting on it. If it does dont buy it, they are proned to cracking.
92GhostRyder
Sep 16, 2018 12:02 PM
BRUISER
Feb 2, 2015 11:25 AM
lews930
Aug 14, 2009 04:20 PM
pulltilbroke
Apr 10, 2009 02:08 PM
MDLP412
Feb 3, 2008 11:46 AM
