98.5 not charging
Old 11-17-2008, 06:22 PM
jivemother's Avatar
Exclamation 98.5 not charging
friends truck i am working in is not charging. new batt.s new alternator. tested good .alternater putiing out 35-40 v. cables apper good grounds are good still gage reads 10 volts . truck will run shut it off batts are dead have to jump again , belt is good 98.5 2500 4x4 reg cab all stock 24valve
Old 11-17-2008, 06:42 PM
tboling's Avatar
Is the alt fuse good under the hood ?
Old 11-17-2008, 07:04 PM
dozer12216's Avatar
Yes, check the large fuse on inside of large box, left side. Should see 14 volts at batteries when running. JMHO
Old 11-17-2008, 08:22 PM
Barney's Avatar
Has anyone changed an oil filter lately? Its real easy to accidentally touch the + terminal on the alternator and blow that fuse.
I think is a 140 Amp flavor?
Old 11-17-2008, 09:15 PM
jivemother's Avatar
if that fuse is blown will u still have power everwere else ? off the batts.?
Old 11-18-2008, 05:29 AM
dozer12216's Avatar
That is a correct assumption.
Old 11-18-2008, 10:56 AM
newconcorddodge's Avatar
When you pulled the Alt. out make sure the plug on the back is on good.
My AC locked up and I ended up taking off the Alt. to loosen the belt--then discovering how to take the belt off the right way. But when i put the Alt. back on the plug was not on properly and caused me to not get a charge. Just an idea...
Old 11-18-2008, 01:26 PM
jivemother's Avatar
it was the 140 amp fuse thanks for all the help chargin like a mother
Old 11-18-2008, 05:12 PM
tboling's Avatar
Good deal our JohnDeere service truck has blown the 140 fuse a few times. glade to help
Old 11-18-2008, 07:28 PM
Lockman's Avatar
Where is that 140 Amp fue located?
Don
Old 11-18-2008, 09:48 PM
Barney's Avatar
This is the best picture I can find right now. The fuse is in the black plastic box on the fender well just to the rear of the driver's side battery. I keep a spare in the truck, along with all of my other goodies. Scroll down so you can see figure 27.
http://dodgeram.org/tech/dsl/mt_2_feb98/fuel_sys_2.htm
Here is the TSB for adding a plastic cover to the B+ terminal on the alternator.
Plastic Boot To Protect The Electrical Harness B+ End Terminal At The Generator
http://dodgeram.info/tsb/2000/08-23-00.htm
Old 11-18-2008, 10:20 PM
Lockman's Avatar
Talking
Thanks a bunch! I'm new to this diesel game and I'm trying to learn all I can.
Diesel-Dan
20
09-22-2019 09:34 PM
GLHS
02-25-2011 10:12 PM
Smokin96_12v
01-21-2010 01:06 PM
matchhead
04-19-2005 06:13 PM
Beerrunz
03-01-2005 02:06 PM
Quick Reply: 98.5 not charging
