98 12 valve trans question
Old 11-21-2006, 06:14 PM
artieb's Avatar
Hi, I'm looking to buy a 98 12 valve, quad cab and was wondering if much improvements have been made in the automatics since 94 to 96. My family has had them rebuilt and don't have to much confidence in them. I can't afford to buy a truck and put 3-4K in a trans.... Thanks, Artie
Old 11-21-2006, 06:33 PM
clutch1's Avatar
All depends how you use it, my dad has a 94 all stock and has a little over 300,000 on the clock and hauls 10,000lbs maybe 4 or 5 times a year. Only prob he had was the temp sendor and tps.
Old 11-21-2006, 11:56 PM
CGA03's Avatar
As long as it isn't bombed a ton and beat, try to buy a lower mileage truck. Or get a 5spd, which is what I'm gonna be buying.
Old 11-22-2006, 10:41 AM
artieb's Avatar
Thanks CGA03 and CLUTCH1, I have thought about a manual trans as well. I was wondering if Dodge did some improvements through the years with the automatics? And what automatic transmission would a 12v have in 98? I have been looking for a truck with a 6' bed, are these called a "Sport"? The short boxed seem to go cheaper than the long bed 8'. Is this my imagination? Thanks, again, Artie
Old 11-22-2006, 12:11 PM
CGA03's Avatar
I believe its a 47RE, I bet they made a few adjustments but nothing probably extrodanary. Not sure on the SB vs LB thing, brobably just the buyer and condition the truck is in.
Old 11-23-2006, 10:54 PM
chop342's Avatar
Location: Climax, MI (between battlecreek and kalamazoo)
it is a 47RE and the only changes made are lack of a govenor housing in the overdrive unit, shorter output shaft (more prone to breaking upon bombing) and addition of govenor pressure sensor and govenor pressure solenoid in the valve body, and addition of low reverse check ball in the valve body. but no strength improvents were made to the RH to RE unit.
Chris
nvr-enuf
05-10-2011 02:49 PM
scottmn1
01-25-2007 07:53 PM
skinsey
07-17-2003 05:47 PM
1320
05-17-2003 03:28 PM
phildog
04-02-2003 05:44 AM
Quick Reply: 98 12 valve trans question
