8' FT, Change out
Old 11-06-2009, 05:20 PM
schoust's Avatar
8' FT, Change out
Hey Guy's I am getting ready to change the Bed on my truck and was wondering if there is an easy way to do it?? Also is there anything I should do under there while I have it off??
Old 11-06-2009, 05:55 PM
2500superram's Avatar
i would paint under the bed and clean up any rust excessable on the frame
Old 11-06-2009, 07:36 PM
Blueboy's Avatar
It is not a hard Job. Pull fuel filler and vent hose.
Ground strap on right hand side of cab.
Light plugs and 8 bolts.I just took mine off
sanded and painted with Por 15.
Old 11-07-2009, 07:33 AM
schoust's Avatar
So when you did it how did you pull it off? There has to be a specific procedure that is easier??I don't have much help so I have to do things smartly...
Old 11-07-2009, 07:46 AM
Purplezr2's Avatar
Do you have a tractor or bobcat, that makes it real easy with a couple of straps.
Old 11-07-2009, 01:47 PM
SIXSLUG's Avatar
You might also want to check the fuel tank cap and fittings while its off. Some have had junk get in the tank because of loose fittings.
Also, set up some saw horses with 2x6's to set it on once you pull it off. Saves backs!
Kurt
Old 11-07-2009, 04:07 PM
schoust's Avatar
Yea I have a backhoe I supose I can crank it up with that? I was thinking about just using my chain fall and hoisting it up with that. Will I need to put new mounts down? It is a 95....
Old 11-07-2009, 05:17 PM
Blueboy's Avatar
I think there are a couple rubber cradles in the
center yours rest on, as long as there ok pull
bolts and take it off. No need to change anything.
bradshaw106
11-27-2009 12:06 PM
dodgebowhunter
06-29-2009 08:59 AM
jmccart
13
05-27-2009 09:45 PM
markm4
07-29-2007 11:16 AM
doitl8r
06-04-2004 11:14 AM
Quick Reply: 8' FT, Change out
