No Turn signals
Old Nov 7, 2009 | 03:17 PM
Cashless's Avatar
No Turn signals
I will try to keep this short. I just replaced the heater core in under four hours. everything works except the turn signals. The hazards work, Brake lights work. windsheild wipers work. highbeams work. but no turn signals. I also can not find any blown fuses. Could I have pulled a ground loose or something like that. Help me find out where I went wrong before I get pulled over for no turnsignals.
Old Nov 7, 2009 | 03:39 PM
patdaly's Avatar
If you activate them, do they come on, but no flash?
Switch you hazard and turn signal flasher and check.
If not, then it is time to start checking connections, I assume you rolled the dash back or removed it?
Old Nov 7, 2009 | 06:56 PM
Cashless's Avatar
I foundit shortly after I posted the question. I had a wire connected to the fuse and it had pulled the fuse out just a smidge . Thanks guys
whazzup
Jun 21, 2004 06:44 AM
signature600
Apr 22, 2004 07:30 PM
Sky-dogg
Apr 5, 2004 02:26 PM
HitTheRoad
Jan 20, 2003 10:20 PM
boehunter49
Nov 28, 2002 06:41 PM
