4wd dash light 2006 Ram
Old 11-15-2011, 07:04 PM
Reelay's Avatar
Installed a new sensor switch that is located on the top of the transfer case. Had a problem of the light not working when the 4 whelel was engaged checked all the usual stuff wires and bulb. Did the bulb check with the trip meter and a wire check by un plugging the connector on the switch and putting a jumper wire between the two. Only problem is that the switch was $33.45 but probably cost the dealer $5.00 but it did the job...
p0wd3rp1l0t
06-27-2012 10:29 PM
NoSparkplugs
17
05-17-2009 10:36 PM
MoparMarv
04-21-2006 12:43 PM
Bobcat698
08-01-2005 03:48 PM
Hummin Cummins
15
03-06-2003 06:45 AM
Quick Reply: 4wd dash light 2006 Ram
