#4 fuel line
Old Mar 8, 2010 | 08:10 PM
Flatbed24v's Avatar
#4 fuel line
My boss has an 04 with a bully dog, intake, exhaust. His #4 fuel line keeps breaking. Is this common? Is there a fix? He has had to replace it about 4 times now and at $80 bucks a pop it gets expensive.
Old Mar 8, 2010 | 11:26 PM
bansh-eman's Avatar
Do a search the #4 line is common to break. 80 bucks a pop roadside robbery! Tell him to call a local Cummins distributor and you can gt the lines for like 22 buck shipped.
Old Mar 9, 2010 | 08:02 AM
Shorts's Avatar
Yup #4 is common. Look at the lines and you will see little blue clips holding the lines. The screws in there wiggle loose then the lines vibrate and eventually break. Get that little screw secure.
Old Mar 9, 2010 | 06:14 PM
vj_M's Avatar
i agree with bansh-eman 80 is highway robbery ive payed 38 here in canada at the cummins dealer...
Old Mar 9, 2010 | 06:16 PM
illEatUrDuramax's Avatar
agreed, those clamps play an important part on CR injector lines. make sure they are tight
Old Mar 9, 2010 | 06:45 PM
shep1's Avatar
Can These be over tightened? Do they need to be torqued?
Old Mar 9, 2010 | 07:12 PM
1985cucv's Avatar
just snug them with some red loctite
Old Mar 9, 2010 | 07:19 PM
i dont believe they can be overtightened, my guess is the more tight they are the less the lines will move around causing them to weaken. yes they should be torqued, im not sure how much tho.
Old Mar 9, 2010 | 09:14 PM
Flatbed24v's Avatar
Thank you for the info
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
RoadDiesel
Jun 16, 2007 09:24 PM
Begle1
19
Aug 25, 2006 11:31 PM
