370 injectors? Which fuels the most?
Old 02-18-2008, 06:40 AM
Troutstrannysvc's Avatar
After getting my injectors pop-tested and to find out they failed I am in need of a good set of injectors..
Who makes the best set of 370s?
I see Hot Rod, New Era, ect...
Just want some input from guys who are running these!
Old 02-18-2008, 06:47 AM
dzlfarmboy's Avatar
I'd opt to go with some DDP's their spray angles are alot better then the 370's and atomize better.
Brett
Old 02-18-2008, 10:20 AM
TxDiesel007's Avatar
agreed
you can go much better than 370s...but if its what you are set on, hotrods are hard to beat. And a member here is selling a set iirc...
Rick
Old 02-18-2008, 10:24 AM
displacedtexan's Avatar
Your sig says you already have a set, if (when) I upgrade the ones I'm fixing to install, I have looked pretty hard at the II Dragon Flys. I've heard some good things about them, and all the bad has been from guys that haven't run them.
Dougk
06-03-2009 07:38 PM
Bradleysram
19
05-12-2009 08:36 AM
dodgeman01
13
04-15-2003 08:04 AM
R-O-B
15
10-31-2002 11:49 PM
Quick Reply: 370 injectors? Which fuels the most?
