370 injectors? Which fuels the most?
After getting my injectors pop-tested and to find out they failed I am in need of a good set of injectors..
Who makes the best set of 370s? I see Hot Rod, New Era, ect... Just want some input from guys who are running these! Thanks |
I'd opt to go with some DDP's their spray angles are alot better then the 370's and atomize better.
Brett |
agreed
you can go much better than 370s...but if its what you are set on, hotrods are hard to beat. And a member here is selling a set iirc... Rick |
Your sig says you already have a set, if (when) I upgrade the ones I'm fixing to install, I have looked pretty hard at the II Dragon Flys. I've heard some good things about them, and all the bad has been from guys that haven't run them.
