366 spring trouble!
Old May 15, 2008 | 08:57 PM
city slicker's Avatar
366 spring trouble!
Ihave really liking this old truck, but the time came to put in the 366 spring. So I did, it was pretty staight forward( so I thought) . Now its been apart 5 times and the last time I made sure all the internal were working properly and it stiill wont start. Any heip would be Greatly apperciated.
Old May 15, 2008 | 09:05 PM
sdstriper's Avatar
I suspect your throttle lever is on the shaft wrong. Remove it and turn the throttle lever shaft by hand. You are feeling for the gov' spring tension, just to the point of tension, then install the throttle lever back on to it's previous indexing. You did make note of that? A couple lines from the right is where I have seen them installed, including my own. That is standing in front of the truck facing it...
Old May 15, 2008 | 09:49 PM
366 trouble
I was careful to index it properly but I'LL CHECK. Also the fuel volume goes up accordingly with the gas pedel.
Old May 15, 2008 | 09:58 PM
PapeCAT's Avatar
to be sure, press the Skinny pedal all the way in while starting to test if your shaft indexing is correct.
Old May 15, 2008 | 10:08 PM
366 trouble
I'll do that. It's kind of wierd. it seemed like the job easy. One more thing, now it has fuel coming from the throttle shaft could that be pulling in some air? but it seems like it's getting a lot of fuel through the injectors. thanks
Old May 15, 2008 | 10:51 PM
BearKiller's Avatar
Mine has poured a leak all winter and never hesitated to start.
BUT, you should pull the pump-top again, push out the throttle-shaft, and replace the little O-ring on it.
If it persists to leak after that, then you will probably need to replace the throttle-shaft bushing.
Old May 16, 2008 | 12:06 AM
Tron's Avatar
Just by chance...the fuel shut off isn't disconnected is it?
Old May 16, 2008 | 06:51 AM
366trouble
no and clicks likeits working but im still gutting it and trying again..... stll there's lots of fuel coming out of the injector lines.
Old May 16, 2008 | 10:32 AM
MikeThomas's Avatar
Its possible to disrupt the manual kill switch and have it not start. Happened to someone I know.
Old May 16, 2008 | 09:17 PM
366 spring trouble
I cecked and made sure it was working the no fuel linkage. I got it running today. Runs ok need to try to make better adjustments to afc and full fue but I'm not getting the boost or fuel I was.
BurrisWill
Jan 25, 2009 08:23 PM
city slicker
May 16, 2008 06:49 PM
b1eric
Jun 12, 2007 08:46 PM
Mike T.
Feb 3, 2007 07:19 PM
vinny
Nov 15, 2005 10:55 AM
