366 spring & smokey pin
Got it done and it is sweeeeet, it made a world of difference.
For those of you like myself
who feel you cant do it on your own, find someone who can help you and go by the sticky; it's worth it. The only thing we had to do was adjust the TPS afterward. It's amazing, while I had my foot in it injoying the moment, I was already thinking about injectors. I guess there's no turning back now.
Thanks guys for the all the support and info.
Hello, I plan on trying to do the spring and fuel pin in a month or so when it warms up. Did you need to get a gasket set to replace the pump top gasket or is it reuseable? Also what did you have to do to the TPS? Thanks
The pump top gasket is reusable. However, it's not a bad idea to replace the throttle shaft seal. I didn't, and I haven't had any problems yet, but it's not too hard to do.
Adjustment procedure for the TPS is here: http://www.piersdiesel.com/Tech1GTPS.htm
I did get a gaskit kit just in case but I didn't need it. It cost about $20.00 plus shipping. The the volts to the TPS ended up being to high after the 366 spring and it would'nt shift into od. The adjustment is easy and it's in the sticky.
Cowboy_Customs
Oct 18, 2011 01:46 AM
wheelieking71
Mar 8, 2011 03:58 PM
jimbo486
Dec 31, 2009 07:36 PM
KRB
Nov 27, 2007 03:34 AM
BigWaylon
Oct 7, 2006 06:28 PM
