300-400hp With Twins/ Single ????
Old 06-28-2009, 08:31 PM
winkdemon's Avatar
Hey Guys , I Am Running A 12v 1995 , I Have A Set Of 370's And 0 Plate 3000rpm Spring . I Know That The Stock Turbo Is Not Enough Air For It , As I Want To Pull My Rv Trailer . So I Was Thinking Twins , But Do I Need Them , Or Should I Just Go With A Bigger Single Turbo , ??????
And What Should I Use For Turbo /turbo's .
Old 06-28-2009, 09:44 PM
JohnX's Avatar
I think you'd probably be happy with the turbo I have in my sig. Phat shaft 62.
Spool is decent and it cools egt's with out any trouble.
Go to some 4 inch exhaust if you haven't done so already.
Old 06-28-2009, 09:48 PM
winkdemon's Avatar
i have a 4 inch exhaust from turbo back , custom made intake , and a bhaf air filter with 5 inch custom made tube to get it to the turbo , the other stuff is still on the wall waiting to get played with lol
Old 06-28-2009, 09:51 PM
winkdemon's Avatar
i will look into a phat shaft 62 , i was thinking a small set of twins but i am not sure .
Old 06-28-2009, 10:37 PM
JohnX's Avatar
Don't get me wrong, i'd like a set of twins, but I don't think the need justifies the cost for our HP levels.
Old 06-28-2009, 10:47 PM
BigErksG2's Avatar
If youre only looking at 300-400 hp, I would look at a hx35/40 hybrid with a 14cm housing. Its cheaper with better spool but getting close to 400hp might get a little warm. bump your timing so you can really use the 3k gsk and injectors.
Old 06-28-2009, 11:11 PM
Tate's Avatar
Stock turbo will be alright for 350hp. If 400hp is all you're after, I'd look to a 57mm turbo.
Old 06-28-2009, 11:21 PM
winkdemon's Avatar
but pulling alot of weight when my trailer is full , and i like to pull hills at the speed limit , as well as pull by the chevy thats pulling the boat LOL
Old 06-28-2009, 11:30 PM
Tate's Avatar
57mm will do ya. There is a noticable difference in spool from stock to a 62/71, I imagine a 62/65 would be quite similar, if not qute as much.
Old 06-29-2009, 12:13 AM
dieselman2300's Avatar
I REALLY liked my 62/65/14 when I was pulling my 8k camper around. My family and I go all over the USA.
I think if your going to do a 57/65/14, I personally would just go to the 62/65/14 or 12. If you have the extra coin you can get the 13cm Stainless Steel turbine housing.
You can also do one of these.
http://www.citydiesel.net/dodgezilla...ml?cPath=32_34
Only downside is they have a tendency to break shafts if they are fueled to hard and you bark them alot.
It will put you over 400 with either.
Old 06-29-2009, 09:24 AM
j-fox's Avatar
Auto trans or manual?
Old 06-29-2009, 10:48 AM
winkdemon's Avatar
auto , triple disc torque , shift kit ,
Old 06-29-2009, 11:11 AM
RowJ's Avatar
Exactly the right question!
'Winkdemon' - Take all responses from manual trans members with a grain of salt.
Larger turbo lag is much more irritating (and smokey) with an automatic because you don't have the luxury of winding out the gears to keep the turbo spooled.
Twins are a dream to drive... if doable.
If not...stay on the small side of "bigger turbo". I would definately avoid 14 cm2 turbine housings.
Live with slightly higher egt's and enjoy your towing more.
I agree with 'Tate'.... check into the BD SuperB! Best of the 400+/- hp turbos, IMO.
RJ
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
kingofdodge7131
03-09-2003 11:19 PM
Quick Reply: 300-400hp With Twins/ Single ????
