2003 Won't start
Old Mar 19, 2009 | 04:16 PM
andywells's Avatar
2003 Won't start
I have a 2003 3500 manual transmission. It has 60 HP injectors, Edge Juice w/ Attitude, FASS 95 gph, AFE ProGuard 7 Stage II intake and Pro-Flo 5" exhaust. Last time I started it the stereo caught on fire and I shut it down. It had blown three fuses. I took the stereo out and replaced the fuses. Now when I try to start it, the lift pump doesn't come on nor does the preheaters. On the instument cluster the voltage and fuel level guages do not show andthing. When I do the cluster check all of the guages work. When I try cycle the key three times it will not show P codes. When I did the C code check I got several codes:
27 64
29 64
81 00
A3 17
AA 00
00 00
One of these says no communication with ECU. I checked the fusable link coming off of the Integrated Power Contol Module and it is good. I don't know if the ECU is fried or I have lost communication with the clust some how. Any help would be much appreciated.
Old Mar 19, 2009 | 05:13 PM
03RAM2500's Avatar
Possibly try unplugging the negative cable on each battery for 15 min. or longer. I think I remember reading somethng about doing that to reset it but I may be wrong.
Old Mar 19, 2009 | 05:20 PM
andywells's Avatar
I had the batteries unplugged for about thirty minutes today while I took the fuse panel out and checked all the connections on the bottom. No change.
Old Mar 19, 2009 | 07:23 PM
03RAM2500's Avatar
Have you tried unhooking the edge? Just a thought. Sorry about your truck.
Old Mar 19, 2009 | 07:45 PM
andywells's Avatar
I have not tried that yet. I will go try that now.
andywells
Mar 29, 2009 04:04 PM
frostedbarleypo
Sep 4, 2008 10:39 PM
bbrusseau
Mar 4, 2008 07:33 PM
steffan
Jan 9, 2007 09:24 AM
Nomad12859
Mar 21, 2006 01:01 PM
