2003* anyone knows how to raise the front 1-2"?
Old Sep 18, 2003 | 11:41 PM
pappygtb's Avatar
just wanted to see if anyone has raised the front of their 2500 1-2" to level out the look of their truck?seems that it would be easy,and i dont want to lift it,just level it.spring spacers?who may have such an item and where could a fella get them?thanks!
Old Sep 19, 2003 | 09:23 PM
tobyw's Avatar
Re:anyone knows how to raise the front 1-2"?
Spring spacers are indeed your answer. Tons of guys run them, with no problems. The only issue, as you can imagine, is when you load up the bed or hook up to a heavy trailer, you will now be nose-high rather than level. Not really a problem unless you tow at night, then expect to get a few bright flashes from oncoming traffic. As far as where to get them, just about every suspension mfg out there makes spring spacers, and you should be able to pick a set up for around $100-$150. Installation is very straightforward, and it really helps if you have heavy-duty spring compressors. I have a picture of the spacers and stuff installed on my webpage if you want to check that out? http://www.geocities.com/tobyw2000
Old Sep 19, 2003 | 09:50 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
JC Whitney has them for about $75. 1-1/2" for 2WD and 2" for 4WD.
Old Sep 19, 2003 | 10:12 PM
Crabjoe's Avatar
When parked, why not just use a Hi-Lift jack?
Old Sep 19, 2003 | 10:15 PM
Hoss's Avatar
Now there's an idea......llama. :
:P
Old Sep 20, 2003 | 04:58 AM
Festus's Avatar
I'm loooking at this(http://www.jackit.com/store/cat.cgi?s=dg135dx) leveling kit. Comes with Bilstein shocks and an upgraded steering stabilizer.
Old Sep 20, 2003 | 10:57 PM
pappygtb's Avatar
Re:2003* anyone knows how to raise the front 1-2"?
thanks guys-i will look into these!
Old Oct 10, 2003 | 07:55 PM
Dodgezilla's Avatar
Summit Racing has 2" spacers for around $139.00 plus shipping. summitracing.com
robinlh
Apr 17, 2011 07:10 AM
redneck2thamax
Oct 24, 2007 04:23 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
barryp
18
Feb 13, 2007 05:34 PM
