1st Gen Automatic to Manual Transmission Swap
Old 01-05-2010, 08:11 AM
RollsCoal's Avatar
I am considering buying a 1st gen dually 4x4 automatic truck, and I would like for someone to give me an idea of what all is involved with swapping in a manual transmission?
Is it best to source a getrag or go ahead and use a NV4500?
Obviously I will need pedals, master cyl and slave cyl, clutch, bellhousing, transmission.
What is involved with properly cutting the hole in the floor for the shifter? Will I need a special sheet metal hump to go there?
What about the crossmember?
Would I also need to source a manual transmission steering column?
I want it to look exactly like it came from the factory.
Thanks,
Joe
Old 01-05-2010, 08:34 AM
EClancy's Avatar
i did not switch columns when i went auto-man. it confuses people...
i had to switch crossmembers, maybe i did not have to, but i had it, so i did.
i had to swap both driveshafts
i just guessed and cut a hole in the floor. i also made it a "removeable" trans hump. the rubber floor mat i have covers any edges or joints, so you dont see anything, or the fact the shifter hole is wayyy too big. i am not going fo factory looks.
Old 01-05-2010, 06:35 PM
Use whichever you can find for a price you are willing to pay, but don't pay extra for an NV4500. If you can find a donor truck that would be the simplest way, then you can rob the pedals, the whole driveline and the crossmember.
92GhostRyder
09-16-2018 12:02 PM
SWATPARAMEDIC
10-19-2009 03:25 PM
jefe4x4
08-14-2008 01:23 PM
Captain Insane-O
06-05-2005 11:15 PM
Trebor
03-24-2005 07:15 PM
Quick Reply: 1st Gen Automatic to Manual Transmission Swap
