what is 1689 code on 2000 cummins dodge ?
Old Jul 11, 2009 | 11:26 AM
lee95's Avatar
is my ip shot or ecm bad if codereader cant communicate ?
Old Jul 11, 2009 | 12:51 PM
SAVOY1964's Avatar
P1689 Oil Pressure Control Solenoid Circuit Malfunction from this site:http://www.troublecodes.net/OBD2/Pcodes.shtml#150
Old Jul 11, 2009 | 01:09 PM
johnh's Avatar
1689: no communication between the ECM and injection pump module replace injection pump and you are good to go 1688 should be there also.....
Old Jul 11, 2009 | 01:12 PM
johnh's Avatar
"Be sure to double check the codes.
Anything above P1000 will be Manufacturer specific and may not match the ones listed here.
Check specific manufacturer pages on the site, as some of them,
we list the OBD2 codes on those pages for those specific vehicles"
Old Jul 11, 2009 | 01:17 PM
johnh's Avatar
this is from the same book
http://www.troublecodes.net/chrysler/
Old Jul 11, 2009 | 02:00 PM
Copenhagenjunkie's Avatar
This may or may not be your problem but...............
I also had no comm bet. ecm and ip with a bad edge ez. I removed the ez and sent it to be checked and it was shot. I never had to replace the ip.
Old Jul 11, 2009 | 05:34 PM
lee95's Avatar
thank you guys i will see if the pumpis still under warranty. the owner is going to quit using his french fry oil based diesel in this truck
snowshoebrue
Jan 22, 2006 01:09 PM
Big Deezul
Sep 9, 2005 01:22 PM
jt_gladstone
Aug 9, 2005 11:24 AM
duallydave
Aug 7, 2005 05:34 PM
high country
Mar 7, 2005 12:37 PM
