12v timing
Old 12-01-2003, 12:01 PM
Muted User
Superduty12v's Avatar
12v timing
I was about to do the timing on my wife's truck and mine with the snap-on timing set for the Dodge/Cummins trucks. I was wondering if you had to pull the gear housing cover or if you could just pop the gear off with the cover on and do the timing? Any advice would be great.
-Anthony
Old 12-01-2003, 12:14 PM
Got Smoke?'s Avatar
Re:12v timing
[quote author=Superduty12v link=board=16;threadid=23103;start=0#msg216473 date=1070301686]
-Anthony
[/quote]
Just pop the gear off with the housing on. If memory serve's me correct you take out the oil filler tube and its directly in line with that hole for the puller.
Old 12-01-2003, 12:30 PM
MnTom's Avatar
Re:12v timing
YEP, Memory serves you correct!!!! Just pull the oil filler tube and it is right there. Remember to tighten the upper part of the filler snuggley or it will want to unscrew when you go to pull the filler cap.
Tom
CTD2001
02-03-2007 01:30 PM
GR40RCapri
06-25-2006 12:53 AM
West Coast
03-26-2006 11:09 AM
RonP
02-24-2006 02:12 PM
redhornet
05-28-2004 06:06 PM
Quick Reply: 12v timing
