12V rough/loping idle
Old Jan 23, 2007 | 05:28 PM
smkn97s's Avatar
Thumbs up 12V rough/loping idle
I think its awsome how the pulling trucks sound when there at idle and building boost. What makes them sound so cool? I wish mine could sound thumpy.
Old Jan 23, 2007 | 06:01 PM
Forrest Nearing's Avatar
set the timing at about 35* and put some huge injectors in that dribble fuel at idle
oh, and mill about .080" off the top of the pistons
Old Jan 23, 2007 | 06:22 PM
smkn97s's Avatar
I was told that if i advance timing over 15* i will probaly blow the head gasket. What do you call huge injectors? What does milling .080" off the piston do?
Old Jan 23, 2007 | 11:41 PM
Teddy Bear's Avatar
Lowers compression and provides valve relief if youre running a big cam. Its not necessary though unless youre wanting to make biiig power.
Old Jan 24, 2007 | 06:24 AM
you should be fine up to about 17*
huge injectors are ones that you wouldn't want to drive around with in your truck all the time
what he said about lower compression... oh and they also won't start without ether
Old Jan 24, 2007 | 08:39 PM
smkn97s's Avatar
ok thanks for the info. Im running around 48psi of boost now with stock timing, But if i get my head O ringed and studs how much timing and boost can i run?
Old Jan 24, 2007 | 09:03 PM
what turbo are you running? you're on borrowed time at that boost level IMMO
Old Jan 24, 2007 | 09:40 PM
smkn97s's Avatar
Im not sure, it was on the truck when i bought it. But its not a stock compressor and the exhaust side is non wg. Thats why im afraid to bump the timing up until i get the head o ringed and studs.
Old Jan 24, 2007 | 10:33 PM
b.lee's Avatar
a buddy of mine's 95 CTD lopes alot at idle.
He said it does it because he previously "starved" it too much for fuel...
any truth to this?
Old Jan 25, 2007 | 08:35 PM
smkn97s's Avatar
I have never heard of that but im not an expert.
Old Jan 25, 2007 | 09:10 PM
alexschultz1's Avatar
bigger cammed gassers will lope at idle, im not sure if it the same for diesels
http://www.digitalcorvettes.com/corv....php/photo/519
one bad corvette if i do say so myself
gpshemi
32
Jan 24, 2011 09:41 PM
rage_blue
13
Apr 5, 2009 11:47 PM
01smokin
Jan 13, 2007 02:27 PM
BigBlue
Nov 20, 2002 05:22 PM
