12 or 14 exhaust housing upgrade
Old 07-20-2011, 10:31 PM
autocar56's Avatar
I am going to upgrade soon, should I go all out with 12 or play it safe with a 14, I still have the stock turbo on my 91.5. What king of horsepower gain can I expect?
Steven M
Old 07-20-2011, 10:41 PM
TJE
TJE's Avatar
I was advised by "wannadiesel" to go with the 12cm ex housing! I've never regretted it.
Look at the truck in my signature....I've even towed a 30' 5th wheel with the 12 on the truck!
Good luck
Old 07-20-2011, 10:55 PM
autocar56's Avatar
Thank you for your quick reply TJE, I am seriously considering the 12.
Steven M
Old 07-21-2011, 04:26 AM
Kansascrewcab76's Avatar
I went with a 12cm waste gated when I revamped my turbo with the gds kit
Old 07-21-2011, 05:28 AM
PapeCAT's Avatar
If Stock injectors on your 91.5 I recommend a 12CM 100%. You would also benefit from a MWE SLOT on that cold side when you increase your drive pressure/low end boost.
Old 07-21-2011, 11:35 AM
brainfade's Avatar
With Stock injectors and the 5-speed the 12 is really nice. Won't increase peak HP but it will drive much better and feel much stronger at the bottom of the RPM range because you won't be waiting for spool. If you get into some really big injectors you'll need a bigger housing but you will likely be going to a different turbo at that piont anyway.
Old 07-21-2011, 02:54 PM
Thunderhog's Avatar
I love my wastegated 12cm!
Old 07-21-2011, 06:34 PM
autocar56's Avatar
Thank you guys for your response, I appreciate it
Steven M
Bg enemy
05-10-2013 09:38 PM
cowboyup007
08-17-2011 04:34 PM
dkimmel
08-20-2010 09:46 PM
95black2615
07-21-2005 09:06 PM
HOHN
12-07-2003 02:07 PM
Quick Reply: 12 or 14 exhaust housing upgrade
