Is 1/2 a quart 2 much ?
Old Oct 6, 2007 | 10:19 PM
Roperteacher's Avatar
My truck has approx, 3500 miles on my current oil change. I noticed for the first time that when I checked my oil level it was slightly below the full mark on the dipstick. It has always been on the full, in between changes.
however, I have done more pulling of my large horse trailer.
Mostly through the hot desert, mileage and power are great and running excellent, anybody else see the same results ?
Truck has 8500 miles on the clock
Old Oct 6, 2007 | 10:38 PM
bighornram's Avatar
As long as its in the safe range I wouldn't be to concerned. If you have been towing alot the added labor on the engine may have just sent some out the overflow tube.
Old Oct 6, 2007 | 11:07 PM
Spooler's Avatar
I doubt it used any oil. It is very easy to get a different reading depending on how long the motor was cut off and sitting. Also, may of not been level. You should be good to go with no issues.
Old Oct 7, 2007 | 12:30 AM
wreedCTD's Avatar
Common problem, i think the dipstick is wrong and the motor is holding a quart of oil somewhere that dosent get drained at a oil change.
https://www.dieseltruckresource.com/...d.php?t=171524
Old Oct 7, 2007 | 01:21 AM
Thanks guys, I made sure it was level and overnight parked, even drove it around some with same result, but like I said, BARELY off the full let alone the ADD mark... It was probably reading 80% up the SAFE . I wouldn't care if it did it all the time but this was the first, but I have been really using it hard thi month!!! GOing to ck in the morning and Change oil. I thought maybe it was my airbags, but I lowered them to 0 as well... Thank!!
Old Oct 7, 2007 | 04:45 PM
CatDiesel_762's Avatar
Your airbags could have been the culprit. I notice that if I check the oil in my drive way which has an incline the dip stick will read in the safe zone. If I check the oil on level ground the oil will read right on full.
Shawn
Old Oct 7, 2007 | 10:19 PM
NickBeek's Avatar
Mine uses or expells or somethings about 1/2 quart over 7500 miles. It didn't used to, but it does now. 44K on the clock.
Old Oct 8, 2007 | 02:48 PM
I changed my oil and it was on the full. I added 15 pounds of air to my ride rites and I just checked it again and is showing a half quart low again... So that must be the culprit. I let ALL the air out of the bags in AZ to test this but was still a hair off the full but the bags looked like they still had a little air.. THis must be it!!
snowmanx
Jul 7, 2007 05:48 PM
Common
Oct 5, 2006 11:23 PM
westcoaster
Sep 15, 2006 02:06 AM
Little-bit
May 26, 2006 09:34 AM
Commatoze
Apr 15, 2005 10:37 AM
